light problems
Old Oct 1, 2007 | 07:32 PM
horse_powr's Avatar
Car: 83 camaro berlinetta
light problems
my headlights, marker lights, dash lights don't work. i was driving and they all just shut off. I have turn signals and brake lights. I thought it was the dimmer switch but i checked the yellow wire going into it and had no power then i checked the red power wire for the headlight switch and had nothing there.
before i cut the wiring harness and follow the wire does it go to the fuse panel if so which fuse if not were does the wire go so i can check it were it starts then follow it up
Old Oct 1, 2007 | 10:27 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Re: light problems
It definitely sounds like you blew a fuse. I am not sure which fuse it is, but you should be able to look at the fuse box and check for any fried fuses.
Old Oct 4, 2007 | 11:14 AM
horse_powr's Avatar
Re: light problems
I checked all the fuses and none of them were blown the wiring diagram says it goes into a fusible link does anyone no were that is at. and my hatch release switch doesnt work. im not sure about the int. lights cause they didnt have light bulbs in them
Old Oct 4, 2007 | 02:34 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: light problems
the fuseable links are near the starter, on two big red wires that feed power to the cabin.
TheJoeY88
Dec 31, 2016 07:30 PM
DiabolicalRS
Aug 26, 2015 07:35 AM
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Omega
Aug 10, 2015 12:46 PM
