Pick-up Coil help
Old Oct 3, 2007 | 10:45 AM
the311godfather's Avatar
Pick-up Coil help
I Have a 92 305 Camaro RS and found out that i might have a bad pick-up. when i take the cap and rotor out there is a metal sheild around the distributor. i cant seem to get it off and i need to to take out the screws holding down the pick-up. any help would be usefull. thank you
Old Oct 3, 2007 | 11:34 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Pick-up Coil help
Not sure what exactly you're describing but you've got the dist out? Removed rollpin for gear and removed the shaft?
Before sinking too much into a new pickup coil you may consider purchasing a reman dist. They run around $100.
Old Oct 3, 2007 | 11:42 AM
theres a metal sheild around where the rotor would sit that is blocking me from getting to the set screws holding the pickup coil. if all else fails i was looking into getting a msd distributor for 250. i cant describe what it is that great because i have never seen this before. i havent removed the dist because i didnt see it necessary until i ran into this problem. im going to have my buddy look at it for me he's helped me fix my car before. thanks for the help
Old Oct 3, 2007 | 06:33 PM
naf's Avatar
naf
If you go MSD make sure you get the appropriate model, compatible with the computer controls.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
RedLeader289
Sep 23, 2015 06:50 AM
