wiring harness
Old Oct 8, 2007 | 12:18 PM
92camaroz28ss's Avatar
Car: 92 z28
Engine: fast burn 385
Transmission: t56
wiring harness
i know these cars have 2 harnesses. one goes from the ecm out the pass front wheel well to the engine, and the other runs the body accessories (lights and such) and includes the fuse panel and goes through the firewall above the drivers feet and behind the dash, and also hooks to the bottom of the steering column. (someone correct me if any of the previous statements are false)
what i really want to know is where can i get a new body wiring harness? i have a stock tpi harness for the engine and forsee changing it to OBDII in the next 6 months or so, but i also want a new body harness for oeace of mind, and mostly because ive had a few problems i can not get fixed, mostly a starting problem NO ONE can find. so now im down to replacing everything. should make for a fun project right?
i would appreciate someone pointing me in the right direction. names of companies would be helpful so i can start doing a little research for background info before i do anything with it.
by the way, its a 92 z28 that originally had a 305 but now has a gmpp 350 still with tpi on it. any other necessary info let me know. thanks again in advance for any help contributed.
Old Oct 9, 2007 | 03:29 PM
Car: 92 z28
Transmission: t56
Re: wiring harness
no one has any ideas or has replaced their harness already? i would really appreciate some help or info on this
Old Oct 31, 2007 | 12:35 AM
Geno.'s Avatar
Car: 1987 IROC Z28
Engine: 305/ 5.0
Transmission: 5spd Auto /700R
Re: wiring harness
Try these guys: http://www.camaroheaven.com/ They have helped me with a lot of hard to find items including wiring harnesses. If you call them you can tell them exactly what you're looking for and give them all the car's accessory info. If they can't tell you if they have what you want right away they'll can you back and let you know. Prices are good too.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
