Tach installation problems
Old Oct 9, 2007 | 12:02 AM
EROC88's Avatar
Car: 88 IROC-Z
Engine: 355 T.P.I.
Transmission: t56
Axle/Gears: gm 10 bolt, 3.90 gears
im putting in an aftermarket tachometer, and i hooked it up to the white wire (ignition coil negative) and its not getting any kind of reading. i have all the wires hooked up, and the lights on the gauge are working, what could be my problem?
its an external coil. is there a different wire i could use?
OR, how can i fix the original tach? it gets some sort of signal and registers, but it doesn't start reading anything until the car reaches 2000 rpms. then after that it does move, but does not read accurately. its an 88, so is there a certain resistor i should check?
Old Oct 9, 2007 | 09:40 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: Tach installation problems
all i had to do to my aftermarket tach is hook it up to a hot with key, ground, the tach signal wire off the coil under the hood, and then the light wire .... if you want your stock one back you can find a cluster with a broken speedo or what not and just pull out your old tach and put the new one in.... here i a link to a post i did on how i set my tach up and black out the factory tach
https://www.thirdgen.org/forums/inte...indicator.html
rocn7roc
Sep 21, 2021 02:16 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
