Need help w/ cluster swap
Old Oct 10, 2007 | 08:46 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Hi, I am new to this, and have a question, I am wondering whether or not its possible to swap a digital gauge cluster from a berlinetta to another camaro, what would i need to buy / do?
Any help is well appreciated, Thanks alot!
Old Oct 11, 2007 | 05:38 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Need help w/ cluster swap
You might check with John in RI. He seems to be the Berly guy on site.
JamesC
Old Oct 11, 2007 | 08:03 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Buy a donor car that has the same basic engine as in your car. If your car is a Berlinetta & has a carb engine, find an 82-87 Carb Z28 or Coupe. If it's a MPFI V6 than get an 85-89 V6 Coupe or RS for a donor car. It's also a good idea to try and get one from a car with the same tranny too, but that can be spliced if you had to.
You can't just swap the cluster - it's not that simple. It's a true conversion in that everything has to get swapped to/from a "regular" Camaro in order to make it a success. By having a donor car for parts you will have everything you need for the job and will greatly reduce the amount of wire splicing the projects would require.
Old Oct 11, 2007 | 02:14 PM
Thanks alot for the help, good to fnally have a camaro / firebiird resource to go to. They are basically the only cars i'll ever drive, and appreciate the know-how.
Thanks again
Jeremys87
Jul 14, 2022 09:08 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
Bstrang6
Sep 8, 2015 04:29 PM
355sbcTPI
Aug 19, 2015 04:38 PM
ChevyZ71
Aug 13, 2015 07:30 AM
