How to get to the VATS!!!!!!
Old Oct 14, 2007 | 06:50 PM
sillybird's Avatar
Mother mary of GOD!!!! 4 days wasted trying to get this no stop code 46 problem solved, and everytime I think I have found the vats to test it, turns out to be something else. Do I need to take the whole dash out to find this thing.... Also I have spent countless ours searching this forum for solutions, Has anyone really had any luck with the resistor thing ? I bought a bundle of different ones from radio shack and none of them were labled, I was thinking of trying the resistor thing before I go a different route. Also thinking of trying the bypass module as well.
Old Oct 16, 2007 | 12:57 AM
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
Re: How to get to the VATS!!!!!!
ok so the vats box is a gray looking box. the only way to put a resistor in is to test the chip on the key. thats the only way that you will be able to start the car unless you get a new wireing harness and computer but that is way to expencive.
Old Oct 16, 2007 | 01:08 PM
ZimGTA's Avatar
Car: 88 GTA
Engine: 383
Transmission: 700 r
You can also have the vats programed out of the computer.
Old Oct 16, 2007 | 08:51 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
they wouldnt be, resistors are labeled by their stripes
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
86White_T/A305
Sep 21, 2015 05:28 PM
Winchester1094
Sep 15, 2015 09:48 AM
