Quick VATs question...
Old Oct 16, 2007 | 07:42 PM
Raven90IROC's Avatar
Car: 1990 Camaro IROC-T
Engine: L98 Turbo (GT40)
Transmission: THO400
Axle/Gears: Forged axles, 3.23 rear
I've suspected my VATs module or its wiring is giving me a bit of grief over the past few months, but thismorning I had the car come to a complete stall on me while driving. Now theres a heap of things it COULD be but I wanted to ask anyway.
My question is; can a VATs module failure kill ignition after the car has started? Or does it only come into play once the car is running?
Old Oct 16, 2007 | 08:40 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: Quick VATs question...
A vats problem would only prevent the car from starting.If the car has been giving you problems over the past few months as you stated,sounds to me like possibly a bad alternator and or battery.I would check the alternator first
Old Oct 16, 2007 | 08:44 PM
Nah I doubt its either of them. Its a sudden and complete loss of ignition or fuel (injectors).
Old Oct 16, 2007 | 09:11 PM
Perhaps the ignition switch on the steering column?
Old Oct 16, 2007 | 09:15 PM
Hmmm... ill have to wait untill after work (since the cars on the side of the road around the corner) but ill grab my injector tester diod thingo, and that will tell me if the injectors are fireing or not during the crank-over.
If they are, then i move onto checking spark and fuel, if they arnt then its either fuse (short), ECM or VATs.
Old Nov 2, 2007 | 04:01 PM
racerd146's Avatar
Car: 92 firebird
my car was doing the same thing id be driving along 40 mhp then it would just die no bucking no nothing just 2k to 0 rpms and wouldnt start back up i reset the ecm and it seem to do the trick
Old Nov 2, 2007 | 04:36 PM
xChAoSx's Avatar
Car: 1987 Firebird
I'm not a expert but it could be your fuel pump, ive had troubles with failing fuel pumps and sometimes it takes a couple months and then one day...it just dies for good. Although i could see it being the ignition switch too.
F-body-fan
Jan 12, 2023 01:49 PM
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
