Easiest way to rewire the fog lamps...
Old Oct 20, 2007 | 08:40 PM
oifish's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 TPI L98
I looked at the fog lamps that are currently installed and I noticed that they were unplugged, so I attached a voltmeter to the bulb outlets just to see if they were live or even worked. When I flipped on the fog lamps the fuse immediately blew, so there has to be a short somewhere in the system. I then looked for the fog lamp relay but I couldn't find it, and it looked almost like it had been removed. So I figure I should just rewire the entire thing from the lamps on back. So whats the simplest way to use the existing switch and fuse to wire these lights. Thanks.
Old Oct 20, 2007 | 09:08 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Easiest way to rewire the fog lamps...
You'll still need a relay to do it right.
Here's a how to on wiring fog lights I found while surfing...
http://www.classictruckshop.com/club...h/foglites.htm
Old Oct 21, 2007 | 05:06 PM
oifish's Avatar
Engine: 5.7 TPI L98
Yea I figured I needed to get a new relay I just wanted to get an idea on how to wire it up.
Bubbajones_ya
Oct 25, 2015 08:01 PM
88CamZ
Oct 8, 2015 10:29 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
sbrandon
Sep 9, 2015 07:31 AM
