Do any tail lights work?
If this is in the wrong section move it.
I have a 1989 Camaro RS. It has the tail lights that is made up of 2 rows with a black row in between. Is it possible to replace them with the lights that are made up of the three rows? And can somebody send me some pictures of each type of tail light for Camaros?
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Do any tail lights work?
You can install ANY 82-92 Camaro Tail light into your car. Plug and Play.
If you want to see the different styles available you should just need to
