Power Window not Working?
Old Oct 28, 2007 | 03:47 PM
briwar454's Avatar
Car: 1985 Trans Am
Transmission: THM 700-R4
Axle/Gears: Stock
Wondering if there is anything i can check before i bring it to the shop. the passenger side power window won't go up. it's stuck open just a bit.
Old Oct 28, 2007 | 05:34 PM
xChAoSx's Avatar
Car: 1987 Firebird
Re: Power Window not Working?
Take the passenger window switch off and put the driver side window switch in its place. Turn the key and try it, if it works then the passenger side window switch is bad. If the window still doesn't go up then your passenger window switch is fine and your window motor probably burnt out.
i replaced both my window motors in my Firebird.
Old Oct 30, 2007 | 09:20 PM
briwar454's Avatar
Car: 1985 Trans Am
Axle/Gears: Stock
IT STARTED TO WORK AGAIN! i have a feeling the motor is on it's way out. thanks for the help!
Old Oct 30, 2007 | 09:42 PM
archemedes's Avatar
Car: 1997 Grand Prix GTP (for now)
Engine: 3.8 sc
double check your grounds could be as simple as a bad or loose ground
Old Oct 30, 2007 | 11:38 PM
briwar454's Avatar
Car: 1985 Trans Am
Axle/Gears: Stock
LOL! where are the grounds?
Old Oct 30, 2007 | 11:59 PM
1991ON20's's Avatar
Car: 91 RS, t-topped, man trans.
Engine: 350cid 350Hp crate motor
Transmission: t5 with new stock clutch and parts
Axle/Gears: 3.08 stock -RS
i just felt the burn by paying 240.00(total) for labor on both of my window motors....
I wish i had the tools. damn rivets...
Old Oct 31, 2007 | 12:52 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
The Power Window wiring diagram for 1982 Camaros shows one ground connection for both power windows located inside the driver's side door. I am not sure where inside the door, but you will likely have to remove the door trim panel to get to the ground.
The ground is ONE black wire from each power window switch to the gorund point. The ground point will be one screw with boht wires under it. Each wire will have a terminal lug for the screw to go through and connect the circuit to the metal door frame.
Dave
Old Oct 31, 2007 | 05:08 PM
xChAoSx's Avatar
Car: 1987 Firebird
I had to hammer those rivets off and replace them with nuts and bolts. It worked well.
Old Nov 1, 2007 | 06:51 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
'85 power windows diagram is the same as the '85 camaro in the tech articles (also '86 on there, should be the same though 84 through at least 89)...one ground underneath the center console and two power wires...one solid pink i think and one pink with white stripe. dark blue and brown is going into your driver door window motor from the driver side switch and light blue and gray is going into your passenger door window motor from the passenger side switch. But the ground is the two black wires coming from the two switches underneath the center console for '84 to '89 that i can speak from experience, i can't speak on '83 and down or '90+ with the interior change, maybe someone else on here can clear that up if it's the same.
As far as those rivits, they are a lot easier to drill out if you had a drill and drill bits, lol. Only issue with nuts and bolts are they apparently come loose after a while. I don't know i'm in the process of doing a manual to power conversion and i may get stuck doing the nuts and bolts thing.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
