Interior wiring????
Old Oct 30, 2007 | 01:15 PM
Soupjmpr's Avatar
Car: 1992 Z28
Engine: Need One
Transmission: Need One
Axle/Gears: Stock
Interior wiring????
Any have any ideas on the best way to wire the inside of a 92 Z...that has absolutely no wiring in it?? I have most of the switches I need to include the rear hatch motor/assembly...but have no harness. Should I start from scrath or try and get my hands on a harness some where? Does GM sell interior wiring harnesses?? Thanks
Old Oct 30, 2007 | 03:21 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: Interior wiring????
If you can find a year and model specific wrecking yard donar for the entire interior harness, harvest it. Be sure that it has all of the power accessories that you want or need as adding them later can be a pita.
Hawks carries complete un-cut interior harnesses, they'll run you about $250+- plus shipping.
Sooner or later you'll discover that GM is phasing out parts for our third gens.
Dont bother asking for a complete interior harness.
Been there, done that.
If your build does not require you to keep the computer / efi, you might also consider an aftermarket harness. Your call.
Good luck!
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
penguinpanda0
Aug 15, 2015 06:45 PM
Exxon Limited
Aug 9, 2015 08:13 PM
