kill switch wiring
Old Oct 30, 2007 | 08:04 PM
rs90 driver's Avatar
kill switch wiring
Where do I get and how do I wire a kill switch to a 1990 RS? I hear 3rd gens get stolen a lot and stolen easily. The last owner of my RS almost got his radio stolen and I have a jammed pass door key lock to prove it. I'm thinkin of cutting of ignition power to the coil when the switch is armed.
Old Nov 2, 2007 | 03:28 PM
racerd146's Avatar
Car: 92 firebird
Re: kill switch wiring
fuel pump is a good place to wire a kill switch to if its efi bolth will do the trick
Old Nov 10, 2007 | 03:06 AM
KCGTA's Avatar
Car: 1989 GTA
Engine: 5.7 L L98
Axle/Gears: 2.77
For less than $10, you can get a switch and some wire and disable the ECM behind the fuse block with the switch. It will not start, even with the key to the car. The dash will light up and it looks like it will start, but it won't. Double bonus in that you don't have to disconnect the battery to reset ECM codes. It's also VATS friendly and makes a good back-up to the original system. It's a 10 minute job that in my opinion would drive thieves without flatbeds crazy! GTA should be a capital offense!
Old Nov 10, 2007 | 07:16 AM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
If your vats is still functioning whats the point. you already have a kill switch and fuel disable device in the car.
Old Nov 13, 2007 | 04:05 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
i thought the VATS was enough protection
Old Nov 13, 2007 | 04:28 PM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
vats is easily bypassed
Old Nov 13, 2007 | 04:37 PM
ryan91rs's Avatar
Transmission: 4L60
so you are telling me a person can use a screw driver pop out my lock, tear off the column plastic and do "something to disable the VATS" and drive away in 60 seconds or less?
How? proof is in the pudding my friend.
Old Nov 14, 2007 | 02:04 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
We don't give any info out, it will
give more people the know how
to steal your car
Old Nov 14, 2007 | 05:22 PM
Imadude_134's Avatar
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
How would you wire something like this up?
Thanks,
-Tim-
Old Nov 14, 2007 | 05:29 PM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
ryan why tear the plastic off the column when u can just pop out the plastic piece around the key switch to get to the vats wire
Old Nov 14, 2007 | 05:52 PM
ryan91rs's Avatar
Transmission: 4L60
ya but i thought if there was no signal to the VATS then the engine won't turn. do you have to give it some juice to get a signal?
Old Nov 14, 2007 | 06:37 PM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
ur key has a resistor for the vats i think theres about 15 different key if i remember right and what if a thief has an adjustable resistor circuit that he attaches to these 2 wires until the car starts and im not going to tell you how to make this device but they have them take my word on it
Old Nov 14, 2007 | 06:44 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
Old Nov 16, 2007 | 12:59 AM
KCGTA's Avatar
Car: 1989 GTA
Engine: 5.7 L L98
Axle/Gears: 2.77
Thanks,
-Tim-
Very easily, Tim. Just unscrew the fuse panel from the kick panel. Drop the panel down and cut the wire going to the ECM fuse. Run a wire from both ends of the new cut wires you just made to a switch hidden anywhere you choose in the car. It's pretty simple to do. The trick is hiding all the new wire.
Hey, I almost had this car stolen from me with some punk trying to use the screwdriver technique. Though VATS saved me waking to an empty spot in my parking lot, as stated by others, those who know can bypass it easily. Any extra measure I can take to help thwart some punk thief I'll do. They got to earn it if they're gonna take it. I also have a good alarm on it. Like I said, it would be easier to put it on a flatbed rather than try to figure out how to get it to start. I've also been known to take the coil wire out of my car, yes **** I know, but I love my car, it's irreplacable- too much sentimental value for me!
Old Nov 16, 2007 | 09:17 AM
ryan91rs's Avatar
Transmission: 4L60
but what if you have a line lock and keep the front locked. i bet that would slow them down. as long as the pressure would stay. which it should. but a kill switch is better!
Old Nov 16, 2007 | 09:42 AM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
Can someone tell me what a "VATS" is?
Old Nov 16, 2007 | 09:46 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Vehicle Anti Theft System.
It's a resister in the key. The computer must read the correct resistance value otherwise the ignition and fuel lock down, to keep the car from being hotwired.
Old Nov 16, 2007 | 10:34 AM
82Five-O's Avatar
Car: 82 Sport coupe
oh, i don't have it that's why i dont know what it is. My 82 is just a plain ol' GM key
Old Nov 16, 2007 | 11:07 AM
Jproz1167's Avatar
the vats system goes into a sleep mode for 4-10 minutes after a wrong resistance is read so it's not as easy as just trying another resistance and the car starts.
Old Nov 16, 2007 | 12:52 PM
Car: 1991 Camaro RS
Engine: L98 350 TPI
If the VATS reads the wrong resistance in the key, when you turn the key what will happen?
On mine, sometimes when I turn the key, it just clicks once, turn the key again, click once. Turn the key again and it starts. Would that be a VATS issue? or something different?
BRoss99
Aug 10, 2025 05:08 PM
89GTAOz
May 16, 2020 09:31 AM
Street Lethal
Apr 30, 2019 12:14 PM
Caspar
Jun 19, 2016 11:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
