Voltage Indicator difference from 88 to 91?
Old Nov 7, 2007 | 08:07 PM
kyrenegade's Avatar
Car: 91 Camaro Z28
Axle/Gears: 3.42 Posi Disc
I swapped out my 88 TBI to a 91 TPI. The 88 uses the "L" terminal from the alternator to send a signal to the voltage indicator in the instrument panel. The 91 does not make use of the "L" terminal from the alternator. Instead the diagram shows a ground on one side and hot feed from the gages fuse on the other side. Do I just need to tap into a hot feed on one side and a ground on the other? Wasnt sure it was this simple if the 88 used a feed from the alernator. Sorry so lengthy. Just wanted to explain everything.
Thanks,
kyrenegade
Old Nov 7, 2007 | 09:19 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Voltage Indicator difference from 88 to 91?
Pretty much. Doesn't really matter where it comes from.
db057
Apr 28, 2019 07:45 AM
BAMiller
Sep 14, 2015 06:38 PM
Formula_88AE
Sep 3, 2015 01:47 PM
greenyone
Sep 2, 2015 03:39 PM
RyanJB
Sep 2, 2015 01:27 PM
