disabling tail and brake lights possible?
Old Nov 17, 2007 | 04:40 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
is there a way to hook up a toggle switch to my rear tail lights and brake lights?
like if it was dark and I wanted to still have all power and front head lights but NO rear lights and NO brake lights when the pedal is pressed??
Old Nov 17, 2007 | 05:22 PM
ron reece's Avatar
Car: 92 B4C/1LE CHP camaro 06 vette LS2,
Transmission: iroc, 700r4, auto
Re: disabling tail and brake lights possible?
you runnin' moonshine?
Old Nov 17, 2007 | 05:36 PM
LOL....yeah!
nah just want to be able to cut the lights in the back when I feel the need. ya know what I mean?...LOL
Old Nov 17, 2007 | 05:52 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
No.
JamesC
Old Nov 17, 2007 | 09:42 PM
Originally Posted by JamesC
No.
JamesC
Old Nov 17, 2007 | 11:42 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Running from the cops are we :-p, just playing, newayz the brake switch underneath has 2 wires and when you depress the brake pedal it makes contact internally, on one wire or the other you can cut it and lead it to a switch and then on the other side connect it to the other cut part of the wire, that would cure your brake lights, and as far as your parking lights in the back, figure out which wire that is and do the same, you should be able to get access to those wires underneath the driverside kick panel. Other than that, a one switch set-up, i don't know of, but don't get caught with it, i'm sure it's illegal some how.
In the tech articles there is the wiring diagrams for the '86, check those out maybe you can figure something else out!
Old Nov 18, 2007 | 12:09 AM
yeah I kinda figured it would be splicing in between the wires that lead to the lights somehow. I read on some site how to do it but I forgot where I saw it and I think it was hooked to one switch.
As far is illegal? Im sure it would be if they knew what the switch was for but they would never know unless I told them or was caught using it but then again I dont see that happening. they would probably have to make up some kinda charge for that...
Old Nov 18, 2007 | 12:26 AM
84redta's Avatar
lol yea, probably, i mean you can get a dual purpose switch, one switch face, but in the back have two seperate curcuits.
Old Nov 18, 2007 | 12:41 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Turn your lights off with the normal switch, and you can disconnect the brake switch on the pedal to turn off your brake lights.
Old Nov 18, 2007 | 01:04 PM
yeah I can do that...but I also want to have head lights. Using the normal switch will also turn the headlights off too.
I want to be able to just cut the rear lights
Old Nov 18, 2007 | 02:50 PM
84redta's Avatar
Maybe someone else can explain this...do all the tail lights share a common ground??? Could you create a toggle switch to kill the ground??? I would assume that could kill the brake lights along with the parking lights. Just a thought.
Old Nov 18, 2007 | 03:59 PM
2fast4u92z's Avatar
Car: 2 camaros 1 trailblazer SS
Engine: 346twinturbo, 383tpi
Transmission: t56 and 700r4
Axle/Gears: 3:46 4:11
It would be easyer to cut the ground.
Old Nov 18, 2007 | 04:45 PM
84redta's Avatar
If you simply cut the ground he would never have taillights, he wants to be able to control the rear taillights for stealthyness i'm assuming while keeping his headlights to see where he's going.
Old Nov 18, 2007 | 05:23 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
rig up a relay to cut the ground when a switch is flipped.
Old Nov 19, 2007 | 12:59 AM
2fast4u92z's Avatar
Yeah I know I was just talking in terms of cutting for the relay/switch. I would use a relay.
Old Nov 19, 2007 | 01:48 AM
ding ding ding!!!.we have a winner!
yeah I wanna be able to cut the rear light along with the brakes light when I use the brakes but still have headlights....like if I was trying to get away from someone and they not be able to see where I went...
I know it can be done....Ive seen it somewhere but cant remember where
Old Nov 19, 2007 | 02:00 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
sub scripeds ( too tired to read now) 3am
Old Nov 19, 2007 | 02:18 AM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
I personally don't know how to do it but a friend of mine (Xophertony) does. He has a functioning switch on his GTA so maybe you could shoot him a PM.
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
