88 Formula Electrical problems--Please help!
Old Nov 18, 2007 | 04:15 PM
brandotron's Avatar
Car: 2002 Camaro z28
Axle/Gears: 2.73 stock, stock, stock
I installed an aftermarket stereo head unit in my car yesterday. Before I bolted it into my radio pod, I tested it (with poweramp and sub) and all was fine. Later that night I left the house. I had the radio on when I turned on my headlights. I heard a POP sound when my headlights popped up. I stopped the car and turned off my headlights--but they wouldn't go down! I also noticed my gauges were not illuminating! Even now, the headlights pop up and turn on, but when switched off, they turn off but don't go down. What the heck!?
Well I took it apart today and found that I accidentally connected the ground wire from the stereo to the brown Instrument panel wire from the car (thinking it was black) None of my fuses are blown, I even tested them with a fuse tester. Did I seriously fry something?? Crap!
Old Nov 18, 2007 | 04:35 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: 88 Formula Electrical problems--Please help!
hopefully, it is just the headlight switch or the dimmer module that went bad.
swap out each of those to see if either or both correct the problem.
Old Nov 18, 2007 | 06:24 PM
brandotron's Avatar
Damn. Looks like i gotta donate more to classic industries. Could it be a blown relay or fusible link? Any telltale signs I should look for?
Old Nov 18, 2007 | 06:47 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
There are no fusible links or relays under the dash for that circuit.Sounds like the headlight switch may have popped on you.Try replacing that,you can get one at any autoparts store.
Old Nov 18, 2007 | 06:55 PM
brandotron's Avatar
Thanks for the help guys! I just ordered the headlight switch and dimmer assembly from modern day muscle.
Old Nov 18, 2007 | 07:00 PM
No problem,good luck with it.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
FormulasOnly
Jul 23, 2018 08:47 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
lanceflame44
Sep 25, 2015 12:28 PM
Formula8r89
Sep 22, 2015 04:24 PM
