Lights Dim At 5,500 + RPM
Old Nov 20, 2007 | 07:47 PM
Max's Avatar
Max
Car: '89 Camaro Convertible
Engine: LB9 Heads/LT1 Cam Holley 670 Carb
Transmission: T5 Manual
I searched and didn't find any info so I decided to post:
When I run the engine up past about 5,500 RPMs the headlights and dash lights will dim. The only time it happens is at high RPM.
I'm running a Summit HEI dist. and the alternator has less that 10,000 miles on it. The battery is also fairly new. I am also running an alpine amplifier straight to the battery.
I'm thinking either an aftermarket HEI ignition module or maybee a digital ignition box (6AL etc.) might eliminate the problem.
Any Ideas?
Old Nov 21, 2007 | 02:21 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Re: Lights Dim At 5,500 + RPM
I highly doubt it's the ignition system drawing too much power. It seems to me that it's the alt's rectifier or regulator not being able to handle the high rpm (= high frequency).
I noticed this effect in a rectifier/regulator I built for an outboard engine. To my surprise it quit charging altogether above a certain rpm. I figured it had to be due to a too high turn-off time in an opto-coupler I had used in that design. The same issue would apply (at some point) to transistors used in alternator regulators.
Unless you run at 5500+ for extended periods of time I wouldn't worry about it, or you could install some underdrive pulleys to fix the phenomenon and get some extra hp to go.
Old Nov 21, 2007 | 04:22 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
first I would check your grounds, then I would fix your sig since it is way tooooooo long.
eightsixseven
Dec 16, 2024 01:50 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Irocohio
Aug 12, 2015 08:03 AM
Omega
Aug 10, 2015 12:46 PM
