got a hatch release problem
Car: 85 camaro z28
Transmission: auto to manaul
my hatch wont open when i hit the buttion. the buttion has power and good connection. so i check the relay connector. if i jump it, the hatch will open. i only have power on the buttion side. the yellow wire (look at the wire diagram) connects where to get power? it only show c241 not sure wheres that located
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: got a hatch release problem
IIRC the hatch release wiring is different from an auto to a manual. I saw in your sig that you'r converting and wonder if that's the problem !?!?
I can recall the manual hatch release being pretty straight forward, but the automatic set-up ran thru the starter or something wierd like that. I know that sounds nuts - so I'll look into it a little later to see if I can figure it out !
Edit: Here's the Diagram so you can trace the wiring !!
Car: 85 camaro z28
stupid me. i accidently wire it to my clutch safety switch to work. just gotta put my foot on the pedal to start my car or 4 the hatch release lol.
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
lol nice!
Extra security from people stealing ya sound system.
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I don't know how many times I've been called by a car service center when they wanted to put parts and such in the hatch. "How do you open your hatch? The key doesn't work and neither does the release on the console." To that I would reply, "Did you set the parking brake?"
On the manual cars, the hatch is tied to the park brake, and, in my case, the key doesn't work either.
On the manual cars, the hatch is tied to the park brake, and, in my case, the key doesn't work either. Thread
Street Lethal
Apr 30, 2019 12:14 PM
