89 camaro wont start
Old Nov 29, 2007 | 08:36 PM
lillis375's Avatar
Car: 1989 Camaro
Engine: 355
Axle/Gears: 9 bolt 3.45
hey guys i gave a 89 camaro rs with a 305 currently it wont start when i turn the key i get nothing no lights, sound crank nothing it was having trouble and my buddy touch the starter and it work great i know the battery is good checked that 13 volts the starter is brand new and when my buddy tried the starter again it just clicks i get nothing so ihad it towed home and the next morning it started up perfect all day it worked then today leaving to go to work and nothing and it still wont start just wondering if anyone has any ideas thanks so much Joe
Old Nov 30, 2007 | 05:51 AM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
Re: 89 camaro wont start
CHeck all connections at the starter. Check the ground wire going from the battery to engine block. Make sure everything is tight & is corrosion free. Your buddy touched the starter - did he hit with something or just touch it? That's why it sounds like something is loose to me. You can also have a fusible link going bad - no lights usually means no power coming from the fusible link on the starter.
Do a thorough inspection of wiring & check for power on both sides of your fusible links - wiggle wires while checking for power.
Good Luck,
Corky
Old Nov 30, 2007 | 08:40 AM
lillis375's Avatar
Car: 1989 Camaro
Engine: 355
Good Luck,
Corky
thanks bro i will try that today my buddy took a screw driver and touch something i know it made a spark when he did
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Caspar
Jun 19, 2016 11:19 PM
92camaroJoe
Aug 13, 2015 06:07 AM
