Window Motor Testing/Cleaning
Old Nov 29, 2007 | 09:38 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
I did some searching and was surprised to come up empty handed on this matter. Anyways, I am finally going to switch out my old manual windows for power windows (regulators and motors). I got a set of window motors and regulators out of an 89 Camaro and my main concern is the condition of the motors.
What I would like to know is, how can I bench test the motors and if they work good, what can I do to clean them up and make sure they are lubricated?
Also, is there any good way to fix a bent regulator? One of mine is slightly bent on one of the arms and I think I can just bend it back, but would like to make sure.
Old Nov 29, 2007 | 10:01 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Window Motor Testing/Cleaning
I can't help out with how to clean them up, except for making sure the regulators themselves have lubrication in the channels. Mine were fairly clean when I picked them up.
You can test the motors out of the car using a 12V power source (spare battery, charger, etc). Connect the power to the two terminals on the motor and it should run. I had this done with the regulator attached. The motor will move the regulator the length of its travel, then stop as it encounters resistance. Switch the leads of the power source and the motor will reverse direction.
1992 Trans Am
May 10, 2023 07:19 PM
evan555222
Sep 20, 2016 02:51 AM
pfsteichen
Feb 9, 2016 06:59 PM
neekolzun
Aug 24, 2015 04:59 PM
evan555222
Aug 22, 2015 07:14 PM
