dead break light!!!!!
Old Dec 3, 2007 | 08:24 PM
TYC-FlipSiCan's Avatar
Ok first of all i have a pontiac firebird and the problem is that my rear LH side tail-light is on but when i press break it wont turn on, and the one next to it, and the oppsite side is working fine!?! Also the middle break light right under the spoiler wont work eaither no light at all replaced the bulbs 2 times to. i dont kno y it dont work ive replaced da bulb twice and it works but when i apply break preasure no light, i have no idea whats going on please help thank you.
Last edited by TYC-FlipSiCan; Dec 3, 2007 at 08:25 PM. Reason: forgot to put missing information
Old Dec 3, 2007 | 09:03 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: dead break light!!!!!
if you are getting regular brakes out of the tail lights it rules out the brake light switch down by the pedal. My opinion about the third brake light underneath the spoiler is the contact pad that is between the hatch and the rear of the car by the latch, that gets a coating on it and needs to be cleaned or sanded to make good contact after a while. As far as the marker light on the rear driver side, check the bulb, check the wires, and check the inside of the socket, could be corroded.
jaridjohn
Jul 8, 2024 03:49 PM
hokis
Wheels and Tires
Aug 26, 2015 04:21 PM
justin57
Aug 20, 2015 07:05 PM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
