Firebird Tach replacement questions???
Old Dec 5, 2007 | 09:26 AM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
Has anyone here replaced only the tach on the firebird dash? I want to keep all the other gauges and replace the tach with one that will fit the stock panel. How would i go about doing this? Also my speedo doesn't work because i just swapped in the T-56. Anyone know where I get the SGI box to convert the signal to my stock guage. Wiring confuses me more than anything. I have no idea where to start...
Old Dec 5, 2007 | 06:42 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Firebird Tach replacement questions???
replacing the tach with an aftermarket gauge or a stock one with a high rpm reading? you can get a stock 8k tach that will pop right in, ive got a spare cluster with the 140mph speedo and 8k tach if your interested.
After the holiday season im going to build me a new cluster with all autometer sport comp II gauges, i see no reason why it cant be done, I will be posting the results when im done so maybe that another route for you
Old Dec 6, 2007 | 08:22 AM
Car: 91 Firebird
Engine: Turbo 355
Cool, I might be interested in the cluster swap. Is it a bolt in deal?
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
