fuel sender ground
Old Dec 11, 2007 | 06:21 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
fuel sender ground
where can i find in my dash a good fuel sender ground?
according to my instructions i need the fuel sender ground for after market fuel gauge
and chassis or engine ground is not what i should be using for accurate readings
any suggestions?
Old Dec 11, 2007 | 07:06 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: fuel sender ground
if you cant use the chassis or engine, what left? I think they want you to get a ground as close to the source, battery, as you can to eliminate any extra resistance in the circuit.
Old Dec 11, 2007 | 07:24 PM
Bobby_80s's Avatar
Axle/Gears: no idea
well i guess the answer to this question is another question with an answer.
what is the fuel sender in the tank grounded to?
Old Dec 11, 2007 | 07:47 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
the chassis, i believe its under the rear seats
Old Dec 11, 2007 | 08:19 PM
Bobby_80s's Avatar
Axle/Gears: no idea
right but any screw into the frame of the car will do correct? liek the ground the power locks use into the frame of the car underneath the driver side kcik panel
i just dont wana remove the carpet or the seats if i can help it.
Old Dec 11, 2007 | 08:25 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
any ground will work, the issue is resistance. The further the connection is from the source, the more the resistance, so you may has a slight change is gauge performance, but i dont know how much it may be unnoticeable.
Glowsock
Jul 24, 2025 03:15 PM
Jae992
Aug 27, 2015 09:07 AM
NBrehm
Aug 25, 2015 11:49 PM
justin57
Aug 20, 2015 07:05 PM
355sbcTPI
Aug 19, 2015 04:38 PM
