Wiring Into The Fusebox
Old Dec 4, 2007 | 10:44 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
I did some searching and found that in order to wire my defrost switch, I need to wire it to the ECC and Gauge fuses on my fuse box. My question is, how can I actually wire it to the box? The places behind those fuses are already filled and I am not sure how I can add another wire to it.
Thanks in advance
Old Dec 5, 2007 | 10:41 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Wiring Into The Fusebox
Here are a few pics to explain things for Ya' !
Attached Thumbnails Wiring Into The Fusebox-rearefroster1.jpg   Wiring Into The Fusebox-rearefroster2.jpg
Old Dec 5, 2007 | 12:42 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Thanks, that helps a lot, I thought that those openings were for something else. Pretty easy now that I know what to do
Old Dec 6, 2007 | 06:09 AM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Well, I ran into a problem. When I tested the hook up locations for power, the one for the pink/black wire had switched power (which I believe is correct), but the place for the orange/black wire hand no power at any time (even with engine on). I am guessing that this is not normal and something is wrong. Any idea what could be causing this?
Old Dec 6, 2007 | 09:56 AM
John in RI's Avatar
Besides the 2 wires I circled in my last message there are only 2 other wires to connect. One is the heavy gauge purple wire that leads all the way down the car to the rear hatch shock. The Other is a heavy gauge Orange and black wire that leads directly to the junction box. ( you can see both of these wires to the left in my picture. )
If that Orange / Black wire is not getting power at any time when connected to the junction box than there is a problem with the power supply from the fusebox to the junction box.
Do you place a circuit breaker into the fuse box yet ???
Old Dec 6, 2007 | 11:09 AM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
I put in all the circuit brakers that give power to the junction box and it does have power. I think my problem is that I though the lower wire in the picture you posted was that orange/black wire. What wire should be there if its not the orange/black one?
Old Dec 11, 2007 | 08:47 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Ok, I finally had a chance to hook everything up the correct way. After wiring it all up, I hit the switch and nothing. Do I need to have the cable hooked up to the hatch strut and grounded off of the other hatch strut to get any kind of reaction from the button? When I hit the switch, no lights turn on, no sounds, and no power. Any suggestions?
Old Dec 11, 2007 | 09:59 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
cable needs to be hooked to the hatch strut. my defroster, which came stock, won't work either if it comes unplugged.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
