Wiring Diagram
Old Dec 17, 2007 | 11:02 PM
Thyire's Avatar
Wiring Diagram
Hello, I have very low mechanical skills for automobiles, however, I bought an 89 Z28 Camaro with a 305 engine. The problem is, it idles too high and when I shift it pulls down on the transmission, I've had a mechanic run some diagnostic tests on it and one of the problems that came up said that the throttle position sensor is too low. He believes that it is the cause of the main problem and could be the source for the other problems. So what I am looking for is the wiring diagram for the throttle position sensor.
If it isn't too much trouble, I'd like it if you could email them to me, Joel.Vincent@gmail.com
Any help would be very appreciated.
Thank you in advance.
Old Dec 27, 2007 | 10:40 AM
Thyire's Avatar
Re: Wiring Diagram
Does anyone know where I could at least find them?
Old Dec 27, 2007 | 11:30 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Wiring Diagram
Haynes repair manuals have that info.
Also it's very simple, one terminal, usually a grey wire is the reference 5V, there is a ground, usually black, and the signal wire, commonly blue. At closed throttle, the voltage will be low, less than .7V and raise to close to 5V at WOT.
Old Dec 27, 2007 | 12:10 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: Wiring Diagram at your request.
I wasn't sure if you have TBI or TPI so I will give them all to you. There are two that I have attached and there are 2 more located at the thread below.. These below are mainly for the Body wiring of a 89 Camaro
https://www.thirdgen.org/forums/elec...or-lights.html
If you don't get these, please pm me and I will forward them all by email
File Type: pdf
File Type: pdf
Old Dec 27, 2007 | 07:51 PM
Thyire's Avatar
Re: Wiring Diagram
Thank you, I'm sure these will be useful.
89GTAOz
May 16, 2020 09:31 AM
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
