Remote Coil
Old Dec 27, 2007 | 06:29 AM
Iluvspd's Avatar
Car: 85 IROC
Axle/Gears: 3.43
Remote Coil
I've been searching for a remote coil for an 85 iroc but the part was listed for 87 and up, is it possible or a good idea to install a remote coil. Also I would like to know which is the best brand to use.
Old Dec 27, 2007 | 06:49 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Remote Coil
I went with an accel coil. There are ones that you can use your existing wiring harness on.. Or you can do like I did, Modify the harness just enough to use another coil.. There are 4 main wires on the stock coil. I believe they are only pink and white. You can put pink to pink, and white to white. Then run one side to + and one to - on the remote coil. I believe the white side is the tach side or - side.. Been a while and you might want to look at the schematics. I can post them for you if needed.
Old Dec 27, 2007 | 08:22 AM
kennn's Avatar
Car: 1990 Nissan 240SX
Engine: GMPP Gen0 350 small block
Transmission: WC T5
Axle/Gears: Nissan R200 3.133, Tomei 2-way
Re: Remote Coil
I'm running a GMPP crate motor, GenI 350 with carb, and the HEI. I would also like to relocate my coil as well because the motor was moved towards the back of the car a good 6" from the original location for better weight distribution.
If anyone can comment on what's a good kit that would be great. Right now I'm looking at the MSD skinny cap, but it looks like I'll have to run one of their MSD-X ignition boxes as well.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
RedLeader289
Sep 23, 2015 06:50 AM
