help with window washer motor
Old Jan 8, 2008 | 01:27 AM
pontiacpete's Avatar
does anyone know which wire i will need to test to see if the pump is geting 12v? the washer is located on the wiper motor held by a clip thanks
Old Jan 9, 2008 | 12:08 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Re: help with window washer motor
Visit this link and take a look at the body wiring continued Figure for your model year. Then scroll down to the bottom of the page and take look at either the 84 or 86 off site wiring diagrams (these diagrams show the internal connections for the wiper and pump motors. Note that there is not a direct wire connection to the washer pump motor from any of the wires from the interior of the car).
http://www.austinthirdgen.org/index.php?pid=19
Most likely with the washer switch enabled you should see 12 volts on both the PINK and GRAY wires.
Dave
Old Jan 9, 2008 | 03:42 AM
thanks for link dave very helpful
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
evan555222
Sep 20, 2016 02:51 AM
pfsteichen
Feb 9, 2016 06:59 PM
Randomtask2
Aug 26, 2015 03:34 PM
