power door lock conversion
Old Jan 12, 2008 | 09:56 AM
sadeks8's Avatar
Car: 91 Camaro RS
Engine: 3.1L MFI
Transmission: Hydra-Matic 4L60
im looking to do a power door lock conversiondoes anyone know what parts i need and how difficult this is to do...because this is my daily driver
Old Jan 13, 2008 | 08:36 AM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Re: power door lock conversion
Have a look at this article, pretty much everything you need to know: http://www.p71interceptor.com/thirdgen/powerlocks/.
Once you have all the parts, you can probably do both doors in a half hour, but the wiring will take a little longer.
What you need is 2 lock actuators, 2 bracket linkages (actuator to lock rod), four 1/4'' rivets, and a 1/4'' rivet gun. If you do not already have the wiring in your car, you will also need the lock switch wiring pig tails, actuator pig tails, and lock relay.
I did the install but the locks didn't work because the locking rod wouldn't move far enough. If that happens, just get a can of spray white lithium grease and spray down the entire inside of the lock mechanism.
Hope this helps
Old Jan 15, 2008 | 08:40 PM
sadeks8's Avatar
Car: 91 Camaro RS
Engine: 3.1L MFI
thank you that helps alot i actually just did the job on someone elses car at work today...lol
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
