Tach Wiring
Old Jan 12, 2008 | 01:51 PM
ROADBLOCK's Avatar
Car: 1985 Camaro Z28
Engine: 350ci SBC
Transmission: THM-700R4
Axle/Gears: Stock
Tach Wiring
ok so today i decided im going to swap out my cluster lights with LED's. I also decided to wire up a different tach. I've attached an image, what im wondering is which ones are which(the metal tabs that my old tach plugged into). i need to know which one is the ignition switch, and which one goes to the distributor to actually measure the RPM's.
thanks, Mike
Old Jan 12, 2008 | 02:17 PM
spina74's Avatar
Car: 01 Trans Am Ws6, 92 Camaro Rs
Engine: 6.0, 305
Transmission: T56,700R4
Axle/Gears: 3.90 9", 2.73 10 bolt
Re: Tach Wiring
on the plug behind the gauges it will be the white wire on the right side, and just use a voltmeter on the wires while the key is on whichever wire gives you 13-14volts is the power wire.
eightsixseven
Dec 16, 2024 01:50 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
stalkier
Aug 7, 2015 04:49 AM
