no power!!!
Old Dec 27, 2007 | 08:59 PM
85 camero's Avatar
Car: 85 berlinetta
Engine: 305 lg4 q-jet
Axle/Gears: stock going 3.73 posi
no power!!!
ok so the cars needed a altenator.so i got one went to pull car around to garage it started idled up real high like normal put in gear still ran but when i went to take off it died and wont restart.put new battery in changed altenator and still no power to anything.cant put windows up locks dont work nothing as power.any ideas on what to look at ? its a 85 berlinetta lg4 305/700r4.
Old Dec 27, 2007 | 09:21 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: no power!!!
check all fusible links, i believe there are 3 or 4 right by your starter underneath the passenger side, about 3-4 inches from the starter stud, can't miss the little tubular things, need to test for voltage before AND after the tube to make sure it's getting voltage before and after to rule that one good or bad. There is also one more right by the battery. Do the same. Other's will tell you that you will be able to physically tell if it's bad if it's either melted or you smelled something melt, but mine was not melted, not even affected, and it was bad, the wire melted inside the insulation and showed no physical signs, but i had checked before and after, and i wasnt' getting voltage before OR after, so i knew that one was bad. Fixed all my probs.
Old Dec 27, 2007 | 10:07 PM
85 camero's Avatar
Car: 85 berlinetta
Re: no power!!!
bad *** car been working on mine but i like fuel injected personally.found a form on page three that fits my proplem perfect that i missed.thanks for the help.this q-jets been a pain in my *** since i bought it.
Old Dec 28, 2007 | 03:57 AM
85 camero's Avatar
Car: 85 berlinetta
Re: no power!!!
ok if my fuseable links are bad could i just replace them with hard wires or would this do more harm then good?does it need the fuseable links to run right?
Old Dec 28, 2007 | 09:07 AM
84redta's Avatar
Re: no power!!!
it doesn't need to have the fusible link to run right persay...but if you were to have an electrical surge...your alternator goes haywire and sends 18V through your car or more...then every piece of electronics from your guages to your dome light are screwed. Yes the fuses are there as an added protection, but there was a reason why GM and every car manufacturer uses fusible links, they just changed the form of them over the years (now they are a little square plastic cartridge). I believe it also protects your engines electrical, like all the sensors and electronics on your carb. It's more or less a safety device for your electronics, it's just back in the 80s they didn't make it as easy to replace as newer cars today. I don't know what stores you got around you, but advance auto parts up here has em for GM, for like $3 i think. small price to pay to save your electronics at a later day, ya know? On the contrary i have heard of people putting in things like MAXI fuses, those huge blade fuses, but then again you got a waterproofing issue. Would you rather have the easyness or replacement that you need to spend 10 minutes to waterproof or the fusible links that you cut, crimp, cut crimp and your done. It's all to your preference.
Old Dec 29, 2007 | 01:42 AM
85 camero's Avatar
Car: 85 berlinetta
Re: no power!!!
ok.thanks for the help
Old Jan 12, 2008 | 07:37 PM
85 camero's Avatar
Car: 85 berlinetta
Re: no power!!!
does anyone have a pic of how there fusible links and wires look.all i can find is two wires to my starter and no fusible links.i have 3 black wires by the carb on the passenger side that been cut off and taped(i post pic)also have wire by the battery that looks like it might have went to a electric cooling fan(ill post pic of it to).my mechanic told me the links were bad but i cant find any since ive had time to work on car again.i think he was just trying to get the money out of me.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
