Testing wiper motor?
Old Jan 14, 2008 | 02:36 PM
Brandon2350's Avatar
Car: 1993 Z-71 pickup
Engine: Heavily modified 355 on TBI
Transmission: Had a 4L60e. Now a 700R4
Axle/Gears: Bone Stock
My GM windshield wipers only work on high. I've replaced the electronic module and still no luck. I have no low and the intermittent doesn't work either.
I'm thinking it's probably the switch in the column, but before I dig deep into that I'd like to test the motor.
I have probed the wiring connector that plugs to the module. I found constant power and diagonaly from that I found the wire that powers the high side of the motor. I cant get power on any other terminals. There is also a plastic disc inside the module housing that I assume works as part of the intermittent function.
If anyone has a procedure to test the motor pinouts or the connector pinouts so I can determine which part is defective would be greatly appreciated.
Thanks, Brandon
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
slade5612
Aug 11, 2015 07:19 PM
