I really need some help.
Car: 00' rcsb
Engine: Little boosted 5.3
Transmission: 4l80e
After swaping interior harnesses i have almost got it all complete. but i do have a problem i cannot figure out.
I am not getting power to my starter through my ignition switch. I try and start the car and i have no poer to the purple wire connecting to my starter. I have traced it through the fire wall and found two connecters. onw with a heavy green and the heavy purple with a 2 prong connecter under the drivers feet and then a 4 prong with the same purple and green and three other wires under the passenger side. neither of these is hooked up to anything. can any one point me in the right direction and help me out?
any help appriciated!
Colt
Pics of the connecters
Under passenger side
under driver side
Colt
under driver side
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: I really need some help.
The first picture shows the Park Nuetral switch plug. This thing gets connected to the automatic shifter handle assembly.
I am not sure abou thte other one so let someone who knows for sure tell you about that one. ( my guess is To the Starter relay. )
P.S. Knowing what year the car is and what year the harness were from will help ! I'd say the harness is 89-92 due to the Green wire rather than Yellow as used on earlier years......
Elephantismo
Feb 13, 2019 12:51 AM
