need 86 tpi fuel pump, MAF power & burnoff relay part #'s
Old Jan 30, 2008 | 10:39 PM
bmfIROC-Z's Avatar
i need the part numbers for the fuel pump ,MAF power and burnoff relays on a 1986 305 tpi(gm or gp sorenson)thanks in advance.
Old Jan 30, 2008 | 10:56 PM
n1ffer's Avatar
Car: 1983 Crossfire Recaro T/A
Engine: 5.0L Crossfire
Transmission: Upgraded 700R4
Axle/Gears: 3:23
Re: need 86 tpi fuel pump, MAF power & burnoff relay part #'s
www.autozone.com and www.advanceautoparts.com are great sites for the sorenson and others (sometimes GM), you can search by year, make, model, engine, etc. A great way to check and compare part numbers.
Old Jan 30, 2008 | 11:15 PM
bmfIROC-Z's Avatar
yeah ive already done that, they both(a-zone&advance) give multiple part numbers for each relay, im just tryin to narrow it down to make sure i get the right parts.
Old Jan 30, 2008 | 11:44 PM
bmfIROC-Z's Avatar
ok ,so far i have found that the MAf burnoff relay is gm part #10094701 or gp sorenson part #mr82 and the MAF power relay is gm part #10067925 or gp sorenson part #mr22, can anybody confirm what i have found so far?and i still cant narrow down the fuel pump relay part number,does anybody know the part number for the fuel pump relay on a 86 305 tpi?thanks in advance.
Old Jan 13, 2010 | 12:07 AM
19_IROC-Z_89's Avatar
Car: '89 IROC-Z
Transmission: WC T5
I know this is an old thread, but has anyone confirmed the burnoff relay part #?
Old Jan 13, 2010 | 12:27 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Here are the relays that you need including the GM, Borg, and GP
https://www.thirdgen.org/forums/tpi/...nces-they.html
Old Feb 24, 2016 | 06:34 AM
FireballXL5's Avatar
Car: 1988 FORMULA
Transmission: 4spd auto
Axle/Gears: standard
Look at the connection, one should have 4 pins and the other should have 5,
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
