Tach doesn't work after ignition swap
Old Feb 9, 2008 | 12:05 AM
Bandit5's Avatar
I have a carbed 350 on a 1990 Camaro RS. Put in a crate 350 HO Deluxe about 4 years ago. Last week I replaced the MSD-6A ignition with an MSD-6AL, which is the same damn thing only with a rev limiter. Anyway, after the swap, the tach wasn't working - it was fully pegged. So I took the cluster apart and checked the resistors I wired in there (standard tach fix) and all was fine. When I put it back together and turned the car on, the tach initially moves a little bit when the key is turned to the on position, but after I start it, it just sits there and doesn't move at all no matter that RPM the car is actually running at.
Anyone have a clue what I could have possibly done wrong? Is it possible the tach output on the 6AL is faulty?
Only thing I did differently otherwise was mount the box on the firewall.
Old Feb 9, 2008 | 12:17 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Tach doesn't work after ignition swap
Have you tried swapping the 6A back in?
Old Feb 9, 2008 | 11:08 AM
Bandit5's Avatar
Not yet.
Frozer!!!
Jan 19, 2024 04:55 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Wade787b
Sep 29, 2015 01:15 PM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
