Tach stuck at 7,000 RPM? Help...
Old Feb 9, 2008 | 10:09 AM
Dave Schotz's Avatar
Hey guys... so long story short, a race shop prepping my '89 1LE 305 TPI car... hooks the battery up backwards and kills a couple things...
Master Kill switch for one... And the 'Ignition Module' locted in the Distributor cap as well.
So... after they replace the Master Kill Switch, wire the battery correctly (Don't get me going on that one!)... and replace the Ignition Module... car fires, and idles fine etc...
However... the Tack is just stuck over at 70 (7000 RPM)...
Any ideas on what to do to fix?
Thanks!
Dave
Old Feb 9, 2008 | 07:17 PM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Re: Tach stuck at 7,000 RPM? Help...
Well, the problem is obviously the courtesy of the race shop. If you're unable to make them replace the tach then I guess you'll just have to find an electronics wizard to fix it for cheap, or find a replacement at a junk yard.
Hotrodboba400
Dec 10, 2019 07:07 PM
Zane Story
Oct 8, 2015 12:40 PM
R13_Braz
Sep 18, 2015 05:00 PM
TrevinE
Sep 14, 2015 03:20 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
