confused about rear defrost
Old Feb 11, 2008 | 08:17 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
i went to the local boneyard and i found rear glass with defrost. i pull the glass the purple wire the black wire and the switch. i hooked up everything and what do you know the defrost isnt working. the grid looks to be in good condition. the switch has power cause the 2 button lights come on but when you push the switch the light that is supposed to stay on doesnt even light up. i was just wondering if there is anything else i can look through to see if i can fix it before taking it to an auto electric shop? i searched an could come up with a close enough answer to my situation. so any help would be greatly appreciated.
mikey
Old Feb 11, 2008 | 08:28 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: confused about rear defrost
Did you get the timer module with it?
Old Feb 11, 2008 | 08:31 PM
isnt the time built into the switch or is it something different. because if it is something different then no.
Old Feb 11, 2008 | 08:40 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yeah it is actually, nevermind. Are you sure you've got a good ground at the hatch?
Old Feb 11, 2008 | 08:43 PM
i have it grounded in the factory location and i even sanded the contact and the paint off the metal before i put it on. this is why i am confused...
Old Feb 11, 2008 | 08:46 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
What's your voltage between the orange/black wire and the purple/white wire at the switch?
Old Feb 11, 2008 | 08:56 PM
that i do not know but if i find my mutlimeter then i will check tomorrow. if i cant find it then i have to wait and go get another i will post when i find that out. thanks so far.
Old Feb 12, 2008 | 01:33 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i swapped my 82 hatch glass back to defroster grid type from one of the camaros i junked last fall/year
this thread makes me wonder if mine works or not, the grids and leads and everything are in good shape
if you need any pics of anything, or such from inside of mine in which is mostly gutted currently then lemme know
pics from just after swapping to defroster glass:
good luck
Old Feb 13, 2008 | 03:00 PM
gotta get a multimeter this weekend
Old Feb 13, 2008 | 03:05 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Have you got a test light?
Old Feb 13, 2008 | 03:08 PM
unfortunately no. that stuff didnt get put on the christmas list this time...
Old Feb 20, 2008 | 08:59 PM
i have been re-organizing the house and i found that i have a test light and i found my multi meter. i am embarrassed to say i dont know how to use the meter. and i am iffy on the light. never got to much into how electronics worked but can usually hook stuff up. i have patience if someone cares to give me the step by step. i will have time this weekend to play. so... again any help is greatly welcomed.
Old Feb 20, 2008 | 09:01 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Can you post a picture of the face of your meter?
Old Feb 23, 2008 | 06:25 PM
will do first thing tomorrow
Old Feb 24, 2008 | 08:12 AM
here is the face of the meter
Old Feb 24, 2008 | 08:54 AM
There is a relay and a wiring harness for it, that goes under the console. The current demand of that grid is VERY high, so they don't run all that through the little weenie switch; the switch operates the relay, and the relay sends the high power to the heater grid.
Sounds like you're missing all of that stuff in the console.
Old Feb 24, 2008 | 06:03 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The wiring diagrams in the repair manual show all the relay contacts and timer circuitry being contained within the switch/control.
On your meter to measure voltage, you'll need to put the black lead in the COM terminal, the red one in the VΩmA terminal, and turn the **** to the "DCV 20" position.
Old Feb 24, 2008 | 06:06 PM
Thank you so very much! I will check tomorrow - weather permitting.
Old Feb 25, 2008 | 04:46 PM
here is what i got i have these color wires with this voltage... purple/white-0, pink/black-13.68 and 13.35 with the lights on, blue-0, black-0.01, gray-11.98 with lights on. this is at the switch.
Old Feb 28, 2008 | 02:23 PM
ttt...
Old Mar 3, 2008 | 09:10 PM
anyone???
Old Mar 8, 2008 | 08:17 PM
lots of rain fellas so i really need this fixed... anything
RazorN8
Jan 7, 2022 11:44 AM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
AkDrifted
Aug 17, 2015 07:45 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
