NEED HELP AT WITS END !!!!
Old Feb 12, 2008 | 09:48 PM
Greg D's Avatar
I'VE SEEN ALOT OF POSTS ON HERE AND OTHER SITES BUT I THINK MINES A LITTLE DIFF I HAVE AN 89 FIREBIRD 305 TBI DOESNT MATTER IF ITS COLD OR WARM STARTED OUT AS SOMETIMES BUT NOW ITS MOST OF THE TIME WHEN I KEY THE IGNITION NOTHING HAPPENS BATT..S GOOD I REPLACED THE STARTER ALL THE WIRES ARE GOOD AND LOOK BRAND NEW I CAN HEAR A SLIGHT CLICK LIKE A RELAY CLICKING BUT I HAVE NO IDEA WHERE A RELAY WOULD BE I CALLED AUTOZONE AND THEY ACTED LIKE I WAS NUTS ASKING IF THEY HAD ONE I COULD BUY TO TRACK IT DOWN LOL USUALLY IF I CYCLE THE KEY A FEW TIMES FROM START TO OFF AND WAIT ANYWHERE FROM 5-20 MINS IT'LL START LIKE THERE IS NOTHING WRONG COULD IT BE THE VATS SYSTEM TAKING A DUMP ON ME ?? IT DOESNT HAVE THE PEBBLES IN THE KEYS LIKE I'VE HEARD ABOUT ON HERE IF ITS THE VATS SYTEM HOW CAN I BYPASS IT WITHOUT REWIREING THE WHOLE CAR ? ANY IDEAS WILL HELP ME PLEASE I LOVE THIS CAR BUT ITS DRIVING ME BONKERS !!!!
Old Feb 13, 2008 | 09:54 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Re: NEED HELP AT WITS END !!!!
Not sure if this is any help, but something very similar was happening to my boat's engine (200HP, fuel injected, electronic ignition Evinrude). Turned out to be the Electronic Control Module. I replaced it and no longer have a problem.
Old Feb 13, 2008 | 10:16 PM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
check your fuel pressure it sounds like by cycling key it runs the pump enought to build the pressure i would guess your fuel pump is about to fail
Old Feb 14, 2008 | 02:07 AM
Greg D's Avatar
if it was fuel pump wouldnt it still crank ??
Old Feb 14, 2008 | 07:36 AM
uemf's Avatar
Car: '86 Firebird
Engine: '85 TPI on crate 350
Transmission: T-5 man
Try jiggling the gearshift (if it's an auto ) or pump the cluch petal. I don't think your year has VATS. If that doesn't work, it could be your starter. Have it tested at autozone. I'd probably test the starter first by connecting a test light to the small wire that connects to your starter. if it lights up but your starter doesn't turn over ... it's bad or the big cable that runs from the starter to the battery positive is bad. Just because it looks good doesn't mean it is good (I know from experiance)
Tony
p.s. please don't shout (all caps), some people get offended.
Old Feb 14, 2008 | 07:16 PM
Greg D's Avatar
i've done the jiggle the shifter thing to thats what i thought at first was neutral safty switch that doesnt do anything that is also what i was thinking about doing next was changing the switch the starter and cilinoid are new but i guess its possable it could be bad i'm bout willing to try anything at this point lol p.s. sorry bout the capslock
Old Feb 27, 2008 | 08:13 PM
D5OL's Avatar
Car: Red 92' Firebird
Engine: 3.1 V6 All Raw Power Baby!
Man it sounds like you have the same issue I do. If so does the Idle Air Control valve hum, along with the relay on the Evap can click? Does the Service Engine Soon light play along with the beat until one of the relays on the firewall make a loud click? After that it starts up fine and runs great until it just dies again. I'm tired of bashing my head too! Somebody help!
J-money
Jan 4, 2019 09:45 AM
92projectcamaro
Jan 18, 2016 08:00 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
dbrochard
Sep 7, 2015 09:41 AM
SG91camaro
Sep 5, 2015 10:27 PM
