Do I need new blinker fluid?
Old Feb 27, 2008 | 05:50 AM
chrisblazzer89's Avatar
Car: 1986 Camaro
Engine: 350 v8
Axle/Gears: 10 bolt,disks, 3.23 posi rear
Okay so Hi I'm Chris I'm new and I just bought a 84 camaro z28 5 speed. I need to go get it inspected but the only problem I see is that my left blinker just stays solid. When I turn them on all three bulbs light up but no blinking the right blinker works fine no problem whats wrong with my left blinker? I replaced the flasher under the dash behind the OBD1 port. When I turn my hazards on they all blink fine but the left front (under the front bumper) blinks real dim. Could it be a ground? Can someone please help? Thank you in advance.
Old Feb 27, 2008 | 03:07 PM
aubicon's Avatar
Re: Do I need new blinker fluid?
i would start by swapping the left and right blinker bulbs and see if the problem moves with the buld, if not try running a tempory extra ground and try the blinker again. if the problem is still not found you will have to chase the power back.
Old Feb 27, 2008 | 03:09 PM
87SSTPI's Avatar
Car: 1987 Monte Carlo SS
Engine: Vortec headed 350
Transmission: '89 WC T5
Are all bulbs good? Whenever I have had that problem it was a bad bulb......
Old Feb 29, 2008 | 01:48 PM
Car: 1986 Camaro
Engine: 350 v8
Ok so I went and replaced all the bubls and made new grounds and still just solid lights when I have the the switch to the left. It still works fine for the right side.
Anyone have any ideas?
Whats the best way to clean the sockets that the bulbs go in?
Last edited by chrisblazzer89; Feb 29, 2008 at 01:50 PM. Reason: Automerged Doublepost
Old Feb 29, 2008 | 07:44 PM
vwdave's Avatar
Was there corrosion inside the sockets? On VW's I go and make sure theyre clean, and take a pick and tighten up the probes. Works like a charm.
Old Feb 29, 2008 | 08:53 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Mine would stick solid sometimes after I first got the car, i wigled the handle all aroun anf it started blinking again, its like it was sticking...also when pullingthe cluster out i didnt get it in good and it would stay solid until i fixed it.
Old Mar 4, 2008 | 02:45 PM
aubicon's Avatar
its starting to sound like your switch, sorry to say, i cant imagine that they are cheep. one more thing that you could try to narrow it down, if you feel up to it. try switching the right and left blinker outputs at the switch if the problem changes sides you have found your culprit. you may be able to remove the switch and clean the contacts (not sure).
Old Mar 5, 2008 | 10:27 AM
Car: 1986 Camaro
Engine: 350 v8
Where is this switch located? I get a good deal at the JYs around her I used to work at all of them.
Old Mar 5, 2008 | 11:03 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
the switch is located inside the steering column under the lock plate. It's the thing that the turn signal lever connects to(its white with a hole in the center that the steering shaft runs through). Pull the wheel off, remove the lockplate and you will see it. You will need a lockplate depressor to remove the plate inself. Fishing the wires through the column can be fun.
Old Mar 5, 2008 | 11:35 AM
3rdGenWillie's Avatar
Car: 92 Lo3 RS
Engine: 305 roller tbi
Transmission: t-5
Axle/Gears: 3.08 open
do a search everytime you have a problem. i already did a post on this. sometimes out sockets are touchy. clean the problematic one and adjust contacts, wiggle it, tickle it , scream at it, eventually it will work!
Old Mar 24, 2008 | 10:53 PM
Car: 1986 Camaro
Engine: 350 v8
Ok so its still all messed up. I did notice that on the right (working signal) the short filament blinks but on the left (non blinking) the tall filament lights up and stays solid. From what I know the tall filament is the running light and the short one is the signal right? What could be causing this???
Old Mar 25, 2008 | 08:04 AM
Car: 1986 Camaro
Engine: 350 v8
TTT
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
mfp189
Sep 27, 2015 09:25 AM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
