Smoking heater control???
Old Feb 29, 2008 | 11:21 AM
Dima's Avatar
Car: 2002 Pontiac Firebird (R.I.P 1992)
Engine: 3.8L Ram Air V6 3800 Series
Transmission: 5spd
Axle/Gears: Unsure
My 92 bird is having some heater issues, the controls themselves (not the vents) smoke when and ONLY when the slider control is in the "off" position. I checked all the fuses and none of them are blown...
Any ideas?
Old Feb 29, 2008 | 11:43 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Smoking heater control???
Check the connector in the following link:
https://www.thirdgen.org/forums/inte...ctor-disc.html
JamesC
Old Feb 29, 2008 | 11:58 AM
Dima's Avatar
Transmission: 5spd
Axle/Gears: Unsure
You think it's the same issue? Theirs all "hisses" in any position BUT off, mine just smokes when it's off
Old Feb 29, 2008 | 12:53 PM
JamesC's Avatar
[QUOTE=Dima;3659302BUT off, mine just smokes when it's off [/QUOTE]
Locate the switch, turn the controls off and see what happens.
JamesC
Old Feb 29, 2008 | 07:09 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I've seen more burnt out heater controls over the years than I can even count. My GUESS is that once you pull that control out of the center console you will see it blackened and charred at the dash harness connector.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Doobie52
Sep 11, 2015 06:19 PM
dbrochard
Sep 7, 2015 09:41 AM
Jlanz55
Sep 6, 2015 02:35 PM
Accerrito22
Sep 5, 2015 09:34 PM
