wiring nightmare
Old Mar 2, 2008 | 09:22 PM
dualphoenix's Avatar
Car: two 87 Firebirds
Engine: 1-5.7L 1-2.8L
Axle/Gears: 3.73 and lsd
wiring nightmare
ok so here is one of a few problems i have first i have no dash lights is a pain but i can deal with it till i figure out why my tail lights are first on the list i have been reading post doing searches and still am in the same place....i have replaced all bulbs and i mean every last one from front to back inside and out,second i have replaced all harnesses on all bulbs outside,third all fuses are new.i did find the plug that the tail light fuse plugs into in the back of the fuse box was out so i replaced it and woohoo i have lights in the rear..left signal works fine right one lights up the whole rear and goes solid when i hit the brakes...went to replace flasher units (hazard and turn) found the hazard and replaced but no turn flasher to be found anywhere under the dash i had the hole dash out looking for it couldn't even find Dark Blue and Purple wires for it WTF?on to dash lights new bulbs new headlight switch and dimmer still no lights oh yeah new fuses also now the fun part someone did some wiring to the head light switch..on the plug port A=Orange B=Empty C=Large Red D=yellow E=Red (one they wired in) F=tan or white can't really tell from age should i have a wire in the B port in the harness?and no reverse lights has a B&M mega shifter in it and a mess of wires going to a relay that just sits there like a four or five prong dunno what it does?
Old Mar 4, 2008 | 04:00 PM
Re: wiring nightmare
ok i got dash lights now replaced the transistor and got them working i also found the turn signal flasher it was well hidden in a mess of wiring that i must of over looked but replaced it and still the same with tail lights the wired i found that i thought were for the flasher were for speakers or some thing dunno but there gone now
Old Mar 8, 2008 | 05:43 PM
rodie_27's Avatar
Car: '89 IROC convertible
Engine: 355 TPI
Axle/Gears: 3.45? Posi
Ok, check your tail light ground. I had that exact same problem and replaced the entire light harness to find all it was was a missing ground. I think it's a dark (black I think) wire and just put it on a bolt for the lid latch, after cleaning it off thoroughly. Give that a try first.
Jorlain
Aug 24, 2022 05:11 PM
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
