Crazy speedo. MSD ignition
Old Mar 6, 2008 | 05:40 AM
ekoller's Avatar
I just put in a MSD 6al with Taylor wires and now my digital dash (Nordskog) is going crazy. The speedometer is the main problem saying I'm driving 70+ while still in park. My question is, Where can I get emi/rf suppressing wire for my electronic speedometer sending unit? I've been looking all over and still can't find any unless I buy an industrial roll of it for $1000.
Old Mar 6, 2008 | 09:00 AM
lukn4trbl's Avatar
Car: 2000 SS, M6
Engine: Modified LS1
Re: Crazy speedo. MSD ignition
Where is the sending wire running in relation to the MSD wiring, or spark plug
wires?
You might be able to fix this problem by wrapping a grounded wire around the
signal wires, or moving them to cross at 90 degrees to any of MSD leads (
if they are currently running in parallel bundles).
Old Mar 6, 2008 | 01:45 PM
ekoller's Avatar
Would it be possible to just use coax cable or RCA cables and strip off the ends, both of these are sheilded wires?
Old Mar 6, 2008 | 01:55 PM
lukn4trbl's Avatar
Car: 2000 SS, M6
As a sheild, probably. Any sort of wrap around the signal wire, which is grounded
should improve the situation.
Using the coax/RCA as a signal wire however, I'm not too sure. It depends
how much current is used, and the gauge of the conductor.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
meeklay812
Oct 1, 2015 03:46 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
Zell1luk
Sep 29, 2015 10:36 AM
