what are these 2 wires?
Old Mar 11, 2008 | 06:50 PM
Jgarder's Avatar
1989 camaro RS v8 305 >>TBI<< 700r4
i have 2 wires hanging down under my car.. its not running at this moment (no idea if its related but i have the distributor off anyways)
right next to the oil filter is where they drop down at the back of the engine..
they are purple and yellow together in a plastic tube thing (forgot the name.. refresh ma memory)
im sorry i dont know how else to describe them or their purpose.. but i cant get my car on ramps because its not running, and there is no jacks here that work right now ~ if you need anything else Please ask..
Old Mar 11, 2008 | 06:55 PM
Jgarder's Avatar
Re: what are these 2 wires?
Added information..
ive been searching around here (awesome place) for a while before and after these post.. and i have additional information that actully may be correct..
My car starts in any gear.. the nuetral safety switch is completly disabled.. this really isnt a problem for me because i know how to shift to nuetral before starting it up.
if they are my nuetral safety switch wires.. can i clip then off or tie them off and not care? or is there some serious ill effects to the pcm,emc, or anything from having these disconnected?
Old Mar 12, 2008 | 11:17 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
The purple and yellow, are they THICK or THIN?
If thin, they are the VSS (Vehicle Speed Sensor) wires. The thing, though, is that your car shouldn't have a VSS (they started in 1990 on Camaros), unless somebody did an engine swap.
If the wires are thick, those might be some starter wires but that wouldn't make sense either because they should be INSIDE!
Got a digital camera? A picture of the connector would tell us a lot.
Lou
Old Mar 12, 2008 | 11:31 AM
rangerlaxdude's Avatar
Car: 85 berlinetta
Engine: 350 carb
Transmission: 4 speed auto
should be starter wires. the main wire for the starter is a thick purple one not sure about the other one though
Old Mar 12, 2008 | 03:21 PM
Jgarder's Avatar
car starts with them taped off and not grounded.. so i wouldnt assume it being the started.. they are 2 thin wires..
Old Mar 12, 2008 | 03:25 PM
BigBadLou's Avatar
Engine: TPI
Two thin wires would point to the VSS. But as I said, Camaros didn't have a VSS before 1990. Was the engine swapped by a chance?
As long as the car runs, you're ok.
Lou
Old Mar 12, 2008 | 04:31 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
camaros had a VSS, it didn't run the speedometer like the 90+ VSS but it did tell the computer that there was a transmission and that the car was moving.
Old Mar 12, 2008 | 05:26 PM
BigBadLou's Avatar
Engine: TPI
Yes, they had a VSS but it was the optical sensor on the back of the speedometer. Not the standard VSS in the tranny tailshaft.
Hope this helps.
Lou
Old Mar 13, 2008 | 05:10 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Hope this helps.
Lou
Ahhh yes, you are correct. I could have sworn there was still an electric sensor on the transmission, my bizzle.
Old Mar 13, 2008 | 09:21 AM
BigBadLou's Avatar
Engine: TPI
No problem, just trying to help.
Best greetings to Bayern, btw.
Lou
Old Mar 13, 2008 | 04:49 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Lou
Thanks Lou, I take it you've been out this way being that you call it Bayern. What part of ATX are you in? I grew up in South Austin.
Old Mar 13, 2008 | 04:59 PM
BigBadLou's Avatar
Engine: TPI
You're kidding, you grew up in Austin? Sorry, SOUTH Austin? And moved to Europe? Funny. I grew up in Europe and moved to Austin. I used to live a few hundred km east of you. Moravia.
Sorry for littering this thread, we can take it to PMs.
Lou
Old Mar 13, 2008 | 06:59 PM
Jgarder's Avatar
Lou
litter is fine where i grew up.. so.. about these 2 wires.. whats the problem with haveing them disconnected.. (working on a super beat up car, first car, trying to get it road worthy)
Old Mar 14, 2008 | 12:06 AM
BigBadLou's Avatar
Engine: TPI
Like I said, as long as the car runs, you're ok.
They might be left over from an engine swap.
Do they have a connector on them or are they just cut?
Cheers
Lou
Old Mar 14, 2008 | 04:09 PM
Jgarder's Avatar
just 2 cut wires.. yellow and maroonish (purple).. thats all i really know.. car dont beleive it was an engine swap.. but there was ******* transmission work done to it recently (before i owned it though)
Old Mar 15, 2008 | 11:28 PM
TKR Performance's Avatar
Car: 1985 Pontiac Trans Am
Engine: 6.6 Liter 406 c.i.
Transmission: T-56 6 Speed/ McLeod Street Twin
Axle/Gears: 3.42 9 Bolt Posi w/ girdle
I did a T-65 swap on my 85 T/A and I have similar wires hanging down. They are for my reverse lights. Try and see if they work. That's the problem sometimes getting these cars second (or even forth hand), you never know what other people before you have done.
Old Mar 16, 2008 | 12:46 PM
BigBadLou's Avatar
Engine: TPI
The reverse switch wires are usually green and blue. And they would be under the car only for the 5-sp cars, not automatics.
Lou
Old Mar 16, 2008 | 01:01 PM
Jgarder's Avatar
Lou
lol.. well my car runs so i guess i dont them right now
Old Oct 16, 2008 | 01:07 AM
Daves03's Avatar
Car: 1991 Chevrolet Camaro RS Red
Engine: 305 V8 TBI
Transmission: TH-700R4
test drive the car does the speedo work? if so tie them up and say the heck with'em.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
