automatic transmission shifter electronic question
Old Mar 11, 2008 | 07:05 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
ok i noticed there is an electronic box on the side of my automatic shifter.
I want to do a bunch of fabrication and have light indicators telling me what gear i'm in. no reason but just to do something custom
my question is:
does that electronic box with all teh wires coming out tell the ecm what gear the car is in?
and if so do you think i can have indicator led's or bulbs coming off each wire to light up indiviudally when i shift? and if so will it screw up the signal going to the ecm?
Old Mar 12, 2008 | 04:04 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: automatic transmission shifter electronic question
I don't think there are wires (probably not contacts either) for all gears. That module is a switch which allows the car to start in park or neutral, as well as turns the reverse lights on.
Old Mar 12, 2008 | 07:07 AM
Bobby_80s's Avatar
Axle/Gears: no idea
oh ok good call. damn i wish gm went the extra step, would of been a great spot to add on some gauges.
kinda like some lower model cars and trucks these days that already have the wiring behind a delete plate for like a clock or super duper radio. and all you gotta do is take it from the higher end model version and plug it in.
o well thanks for the input
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
NBrehm
Aug 25, 2015 11:49 PM
redmaroz
Aug 16, 2015 11:40 PM
