Manual Fuel Pump Switch. Right Direction.
Old Mar 12, 2008 | 04:43 PM
jagevileye21's Avatar
Car: 1991 Z28 Vert
Engine: LT1 350
Transmission: T56 6 Speed
Axle/Gears: 3.42 LSD
Due to the fact that I am getting no power from my fuel pump relay. I want to install a manual fuel pump switch. I know I cannot just run constant power to the fuel pump because I would ruin the fuel pump and kill the battery. If I run the fuel pump to a power source that is active(hot) only when the key is in the on position. The fuel pump would constantly run when the key in the on position. The happy medium for me would be to have a manual switch that only get power when the key is in the on position allowing me to control the pump.
Correct if I am wrong on the setup.
Wire from fuse box (that is only hot when ignition is on) to Manual switch
Power out from manual switch to fuel pump (+).
Ground to switch.
Could I just disconnect the relay in the harness?
Engine: LT1 350
Custom Harness: LT1350.com
Old Mar 14, 2008 | 12:48 AM
ej1_sleeper's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: stock non-posi
Re: Manual Fuel Pump Switch. Right Direction.
i would like to know the same thing. im doing a 88 350 tpi swap into a 90 v6 firebird and the 87 harness i picked up has no fuel wiring in the engine harness. Would this be the best way to get the fuel pump to work? id really rather not have to run wires from the bulk head to where ever its suppose to go... also makes no sense cause it came off a TPI engine.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
beachrodder
Aug 25, 2015 08:05 AM
kyleb24
Aug 15, 2015 08:24 AM
92camaroJoe
Aug 13, 2015 06:07 AM
