86 RS instrument cluster swap
Old Mar 16, 2008 | 07:00 AM
svtnutt's Avatar
Car: 1986 Camaro Sport Coupe
I swapped out the stock 85mph spedo cluster in my 86 RS for a cluster out of a 88 with 110mph speedo and 5500rpm redline tach. all went well, the only problem is the turn signals indicators do not light up when I use the turn signals. I did replace all of the bulbs on back of the cluster before install. they worked on the original cluster..... is there some sort of difference between them??? the only other thing I noticed is that the oil pressure guage on the new cluster reads to 80lbs where the old one read to 60lbs
Old Mar 16, 2008 | 03:51 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 86 RS instrument cluster swap
Welcome to TGO. Since electrical gremlins sometimes crop up in "cluster" swaps, I always recommend simply swapping the speedo head (and perhaps in your case, the tach) into your original cluster (if it functioned as designed, which yours apparently did).
JamesC
Old Mar 16, 2008 | 07:41 PM
InfraredMonkey's Avatar
Car: 1985 Chevy Camaro Sport Coupe
Engine: LG4 V8 305
Axle/Gears: 3.08
How's your tach functioning so far?
I know, if the Tach's oil pressure gauge says 80 lbs, then you got yourself a V6 tach or cluster. If you take it apart to swap the speedo or whatever, you might find a small tag that states a set of numbers, then the CYL part will state 6 to confirm.
I bought a V8 tach on eBay for my Sport coupe and half of the cluster doesn't light up and turn signal indicators are dead, the circuit board on the back usually is at fault.
My only suggestion is look for another instrument panel
Old Mar 17, 2008 | 08:31 PM
svtnutt's Avatar
yeah. I kind of figured it out today. drove the car...... and to my delight my little 305 buried a 7000RPM tach.... how awesome is that? Oh well live nad learn. got the piece from a local yard for $20. can't complain. used to be into Mustang's ...... learning something new
thanks
Old Mar 18, 2008 | 06:22 AM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
As JamesC said swap the new gauges into your original housing and reinstall it. Should fix that pesky light problem.
Jeremys87
Jul 14, 2022 09:08 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
Bstrang6
Sep 8, 2015 04:29 PM
355sbcTPI
Aug 19, 2015 04:38 PM
ChevyZ71
Aug 13, 2015 07:30 AM
