Passenger power window problem
Old Mar 16, 2008 | 11:29 PM
daghstdrummer's Avatar
Car: 1986 Z28 Camaro, 2002 Audi A4 (DD)
Engine: 350 .30 over w/bang for buck combo
Axle/Gears: stock for now
First off.. i just finished a tbi to carb swap and completely cut out all of my ecu wires etc... i might have cut the power window cable but am not sure.
but in first start up the drivers side window works passenger side does not.. b4 i began the swap both windows worked
any ideas? if anyone has a diagram of the window wiring that might help..
thanks
John
Old Mar 17, 2008 | 12:20 AM
ljnowell's Avatar
Re: Passenger power window problem
did you mess around by the ecm, under the pass side of dash? if so, there is a good chance you knocked something loose that goes to the door, get down there with a bright flashlight and give a good visual. In my experience at a tech, more cars are fixed with a visual inspection than anything else.
Old Mar 17, 2008 | 06:24 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
http://92b4crs.tripod.com/86wiring/86wiringindex.html
http://www.austinthirdgen.org/index.php?pid=19
JamesC
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
pfsteichen
Feb 9, 2016 06:59 PM
