aftermarket rich lean gauge question
Old Mar 15, 2008 | 10:19 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
i bought this cyberdyne lean rich bar graph gauge.
it uses the 02 sensor as its sender.
does anyoen think or know if this will screw up the signal that the 02 sender sends to the ecm?
Old Mar 16, 2008 | 09:38 PM
Bobby_80s's Avatar
Axle/Gears: no idea
Re: aftermarket rich lean gauge question
anybody have an idea?
Old Mar 17, 2008 | 07:59 AM
lukn4trbl's Avatar
Car: 2000 SS, M6
Engine: Modified LS1
If it's wired in parallel (which it should be), the voltage to the ECM will not
change, but the current will be cut in half.
Unless the aftermarket gauge is a low load type, the signal from the stock
sensor will be strong enough and not cause any issues.
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
redmaroz
Aug 16, 2015 11:40 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
