gauge cluster not working
Old Mar 18, 2008 | 09:28 AM
thelusivetoilet's Avatar
recently i took off the front of the gauge cluster so that i could clean it up, at the time the battery was off the car because i had to replace the battery so after i started it up i had a problem. the right turn signal light was on alittle but only on the cluster, the actual signals on the car were fine, then when i put the left side turn signals on the bulb wont blink and all the other gauges start going wacky, they all go up and down, as if all the electricity is going to power the little bulb instead of the gauges so when the bulbs off they shoot up when it turns on they hit 0. and not to mention the left turn signals dont work , the cluster and the ones outside
could it be a broken fuse? and wheres the fuse panel located?
Old Apr 16, 2008 | 08:57 AM
Ziggyman's Avatar
Car: '87 Camaro
Engine: Stock 88 roller 350 w/ nice heads
Re: gauge cluster not working
I would check the fuses, right by your hood release there should be an access cover for them. On my 87 it was a 10 amp fuse. Mine keeps blowing after I took out my cluster, any suggestions?
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
Reddeath210
Oct 6, 2015 08:20 AM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
