anti-theft system on 92 rs....oh no!
Car: 1992 Camaro RS
Engine: 305tbi, some bolt ons
Axle/Gears: 3.73 posi
i was trying to disconnect the negaive battery terminal so i could install a new stereo, and the BAM, the anti-theft alarm went off, but then stopped after i took the terminal out of the battery. But would start again after i put it back in, and wont stop, so i disconnected the horn, and now theres this flashing light in my car on the left side of the driver dash.
how od i turn the anti-theft system off?????
sorry for the spelling errors above, i am in a rush
Last edited by guitargod2138; Mar 19, 2008 at 11:26 AM. Reason: Automerged Doublepost
Car: 1990 Camaro RS
Engine: L03 305 TBI
Re: anti-theft system on 92 rs....oh no!
Most factory alarms will respond to either:
Putting the door key in the drivers door, and turning it (try both ways)
Putting the ignition key in the ignition and turning it.
I didn't know these cars even came with alarms, VATS yes, but not alarms.
You may have an aftermarket alarm, if thats the case, if the above doesn't work, look under the driver side dash, for a small push button. Turn your ignition to the "on" position, then press and hold that button until you hear one chirp/honk. That puts the alarm in valet mode. Which is pretty much just keyless entry, if it was hooked up. The security light may stay lit while in valet mode. Repeat the process to exit valet mode.
Car: 1992 Camaro RS
while the batter was disconnected, i turned the ignition to on and then reconnected the battery and everything was fine, its back to the way it was normally.
thanks for the info
thanks for the info
Car: 2002 Camaro z28
Axle/Gears: 2.73 stock, stock, stock
Mine has the Goodwrench alarm from the dealer. Under my dash on the drivers side there is a toggle switch to switch between normal mode and valet mode (disarmed). I just leave mine in valet mode.
Pac J
May 17, 2020 10:44 AM
[Sold] Flowmaster exhaust system
Night rider327
Oct 9, 2015 09:25 AM
Night rider327
Sep 25, 2015 04:47 AM
