what wires power fuse box
Old Mar 20, 2008 | 12:09 AM
CAMAROJOKESTER's Avatar
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
hi.. i bought a car that had a tbi set up in it and i swapped over to a speed density set up with the painless harness.. when i was taking out the tbi harness i had to cut some wires that where in the harness, but some of them where from my drivers side.. i have two big red wires and one big purple wire, which wires should i hook up to the battery. i havent tried any yet.. thanks..
Old Mar 20, 2008 | 07:44 PM
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
Re: what wires power fuse box
please help.. I just need to know what wires gives the fuse box power.. thanks
Old Mar 26, 2008 | 03:05 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
You should have figured this out by now, but anyway; one of the red wires powers the light switch and a few light-related fuses, the other red wire powers the ignition switch and all the other fuses. They connect to the battery through separate fusible links. The purple is the crank signal to the solenoid.
Old Mar 26, 2008 | 12:10 PM
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
please pardon my ignorance to the topic. So I need to conect the purple to the starter. I do have a cut red wire in front of the battery and think the red wire that connects to the ignition is suppose to be connected with it to make one wire. Can I run the red wires directly to he battery, because when i look at the diagrams all the red wires are hot all the time. I have 3 thick red wires that are cut, but even if two of the red wires where suppose to be one, if i hook them up to the battery will it do any harm??? I could also put a fuse inbetween them to make it safer. Thanks for the help
Old Mar 27, 2008 | 03:39 AM
The purple coming out from the firewall is supposed to connect to the small post on the starter. The red ones from the firewall are originally connected to the big post on the starter (that is connected direcly to the battery). Use separate fuses for each red wire, and use the big kind, at least 50-60 Amps I think. That way, if you get a catastrophic short in the light circuit you won't lose ignition power. One of the red wires you refer to might be for the alternator charging circuit. Any fuses there must be substantially larger than the alternator capacity.
I can't be any more specific since I don't have the same car as you. If you post a link to a wiring diagram for your car I might be able to provide further advice.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
backtothe80s
Sep 5, 2015 12:39 AM
stalkier
Aug 13, 2015 12:59 PM
