hook back wiring
Old Mar 20, 2008 | 11:47 AM
jean's Avatar
hook back wiring
Hi All!
I'm trying to finish to hook back all the wiring left after an engine 355 carb swap instead of the LG4 on my 85 trans-am and i have one harness left that you can see on the picture . Any idea where it goes? Thanks lot!! (I still haven't found the wire to hook back the original temperature gauge et voltmeter) .
Thanks lot!
http://www.putfile.com/pic/6752240?pos=top
Old Mar 22, 2008 | 05:51 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: hook back wiring
The dirty brown connector looks like the temp gauge sensor connector. If it is that one, it should clip onto the temp sensor in the driver side head, behind the #1 exhaust port. The black plug looks maybe like the O2 sensor plug. I can't see the plug on the other wire, not sure where it goes.
Old Mar 24, 2008 | 10:01 PM
jean's Avatar
ok will hook then that green wire with the orange connector . I would also need some infos on what those wires with the burnt white connector on the picture , Any idea what those wires are for??
http://www.camaro-firebird.com/phpBB...ic.php?t=16737
Thanks lot
midge54
Dec 27, 2019 04:14 PM
Reddeath210
Oct 6, 2015 08:20 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
stalkier
Aug 7, 2015 04:49 AM
